I sharpie'd my CF eyelids cause i had to pull them them off again cause i traded diezzel my mismatched headlight for his so we both had matching sets about a year ago lol, one was shiney and one was grey so now i have a matching grey set.
Before
After
So i finally wired the light for my boost gauge so i can see it at night, it only took about.....2 years? maybe 3, it was put in the car when i did the BPT swap hahahahahaha
I just tapped it to the dimmer but i accidentally wired it to the switch wire and not the dimmer wire, whatever though cause i'm using an LED bulb and i don't think they dim well.
So for anyone wanting to tap to the dimmer and be able to dim, use the solid red wire, but the red wire w/ black stripe.
It looks a little more blue in the picture than it is but i'm using a white LED with a green sleeve i that came with the boost gauge so it only makes sense, i think i'll get a green LED in the future along with the dash.
