[FS] SRD Reproduction Parts - Crossmember, Tie Bar & E-Brake
Re: [GI] SRD Reproduction Parts - Now E-Brake Handle BB!
I'll try to get you the size ASAP
Why is this so hard to get this information? If after all this time, I come home for Christmas, have time to go to the wreckers and get this information....
i guess worse comes to worse, i can go to one too. but i figured with so many people wanting the handle. SOMEONE could tell me the simplest piece of information
I would have had the size if I didn't crash my car
no auto wreckers around here have a mx3,mx6, protege or 626
- Evo_Spec
i would of gotten this for you a long time ago but i can't get the button off because it's square shaped so without cutting off the handle (won't slide off, at least not with my strength) i can't twist off the button
- Ryan
It does slip off with enough strength, I replaced my button with a chromey one from a protege.
getting it back on is way harder, you need to sit the cover in hot water to get it pliable enough. Its super cold out, thats the only reason I'm not doing this
- Evo_Spec
well, let me give it one more shot, be back in a bit.Ryan wrote:It does slip off with enough strength, I replaced my button with a chromey one from a protege.
*edit*
yeah no dice, i realize that even if i got it off i'd have no way to measure the treads...unless i went to home depot and used they're measure board thing or something
if there was a car at the scrap yard. i grabbed a nut that is 5mm, 10-32 and 10-24
They need to be engraved ANNNNNNNND i still dont know the threaded hole in the button
- _-Night-Shade-_
i just cant finish them until I know the size of the thread in the back
- im2bad4ya
Not too late for a lower tie bar???
Can the powers that be message me?
-1992 MX-3 RS w/BP Swap Tropical Emerald Metallic "Lucky" 2005-2012 *REST IN PIECES*
Worklog: viewtopic.php?f=46&t=78176
-2003.5 MAZDASPEED Protege #882 Blazing Yellow Mica "Lemon Drop" 2012-2015 SOLD!
-2003 MAZDASPEED Protege #1186 Spicy Orange "Debbie" 2014-2015 SOLD!
-1980 Toyota Corolla Green 2014-present
-2002 Lexus IS 300 Solar Yellow 2015-present
- _-Night-Shade-_
Did you try the engraving option I told you yet?BlaznLow wrote:i just cant finish them until I know the size of the thread in the back
