Mx3Kid's 93' Mx3 Project (Pics inside)
Re: Mx3Kid's 93' Mx3 Project (Pics inside)
my car the very first day i got it.. lol i just found this picture
CF Hood, Kenwood everything, 2.25 catback exhaust, H&R Springs, F&B Strut bars
My worklog: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=68856" onclick="window.open(this.href);return false;
Good afternoon from the biggest Douch around;D
heres my car lowered on H&R's
Okay.. so just the other day my car did this thing where none of my dash lights/clock anything would come on. when hooked up to jumper cables the battery sparked.. and did this really weird thing were it cause my rpm gauge to moved up and down acording to what electrical accesorie i was using in my car. Such as "Turn lights on, it goes up 2000rpms, turn brights on, it goes up to 5000rpms." wtf right? also when i turned on my hazard lights it would turn off my radio and make my rpm gauge go coocoo for cocoa puffs.
well after that it went dead COMPLETLY dead. i hooked the battery charger up to it and read that my battery was at full charge?
i took the battery out of my dads car and hooked it up to mine and same thing.. COMPLETLY dead.
somebody help... none of the fuses are blown everything looks right, nothing smoked or poped except the battery.. oh witch i will had was leaking water out of the overflow nozzle thing?
Somebody try to help me out please
- onlytrueromeo
Check grounds, especially the battery ground.
hmmm... off the top of my head... If it isn't grounds...
ECU took a dookie?
Will anything turn on/chime without an ECU? I've never tried turning the key with no 'puter.
ECU took a dookie?
Thats what im doing right now. Im making sure all my battery's connections are solid. i did have a weird jimmy rigged thing for the positive connection of my battery so im going to mess with that a bit..
okay well.. i didnt do anything different than last night. put my battery back in and
VROOOM.
wtffff.
runs better than ever? This stupid car has futt bucked me so many times like this.
VROOOM.
wtffff.
- onlytrueromeo
You have bad connections, you need to clean them up and then it won't happen again!
i think your right scotty
I am selling my mx soon ;]
in hopes of getting a volkswagen. i do not trust my car any more. and am tired of it being called a girls car.
- mx-3_4evr
^ I think you are the girl for not being able to figure out what's wrong with it!
Really my friend? Well. If your car went completly dead, you hooked a batt charger up to it. and your rpm gauge started bouncing up and down and your radio started turning on and off..
would you like to tell me where to start.
- onlytrueromeo
^Grounds, I told you. Simple, easy fix.
- mx-3_4evr
^ I agree, check your grounds!
