Mx3Kid's 93' Mx3 Project (Pics inside)
Re: Mx3Kid's 93' Mx3 Project (Pics inside)
oh and jiffy lube wont work on my car... so i went to the mazda dealership and they wanted to hold my car a for a week. so im going to look for some pictures of how to do it myself
CF Hood, Kenwood everything, 2.25 catback exhaust, H&R Springs, F&B Strut bars
My worklog: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=68856" onclick="window.open(this.href);return false;
Good afternoon from the biggest Douch around;D
i had a breaker bar and i was trying to break the strut mounts free and it just yanked it out.. blehhhonlytrueromeo wrote:How did you pull your axle? you must have really been yanking on your hub!
Back are easier to do, but harder to put back in. You won't need the spring compressor for them!. Feel free to use it when taking them off, but the new ones are low enough so u dont have to!
Okay so you do put the tranny oil down where the speedo cable goes?
diagram 4 in this pic shows you where the speedo cable goes in...
http://www.mx-3.com/manuals/showimg.php ... J1-002.gif" onclick="window.open(this.href);return false;
here's how to do it!
http://www.mx-3.com/manuals/showimg.php ... J1-007.gif" onclick="window.open(this.href);return false;
give me a call if you run into any problems
Thank you so much! That is exactly what i was looking for. Your saving me all my money. lolMooneggs wrote:diagram 4 in this pic shows you where the speedo cable goes in...
Okay. Well now that everything is back together! it rides alot nicer now. duh. My braking is different now though? I used to push my brake peddle down about 1/4 of the way and my brake power was there. now i have to press it about 3/4 of the way down before any braking power is noticed at all? and they squeak what the hellll? Should I bleed my brakes and see if that makes a difference?
and it makes a ka-chunk sounds when i go over bumps? is that because of my bad shocks?
- solo_ryder
Yea you should bleed your brakes for sure, probably some air in there.
As for the clunk, could be a balljoint or a bad strut.
guessin bad strut.. considering they kept falling down....
Okay so im lookin for a rear strut bar.. I dont believe something that cheap would actually be good?
http://cgi.ebay.com/ebaymotors/Mazda-MX ... 06.c0.m245" onclick="window.open(this.href);return false;
It's not. But then, the affects of even a good one are debateable at best.
It seems like I noticed an improvement when I installed mine... or was it just in my head?
- Inodoro Pereyra
I agree with Wytbishop.Mooneggs wrote:It seems like I noticed an improvement when I installed mine... or was it just in my head?
If you installed stiffer shocks/springs to use your car for racing, you can, depending on the kind of racing you're doing, notice an improvement, as the chassis may start flexing under the increased stress.
But if you're using a stock suspension, strut bars are just extra weight.
Either way, at least in my opinion, even for racing strut bars are nothing but a half a$$ed solution. If you have flexing problems, some properly designed bracing would solve them much more efficiently.
Diogenes of Sinope.
Diogenes of Sinope.
Inodoro Pereyra wrote:I agree with Wytbishop.Mooneggs wrote:It seems like I noticed an improvement when I installed mine... or was it just in my head?
WELL!! I had just installed my H&R's and a few days later Mooneggs called me up and sold me a front strut bar. and i couldn't believe how much it helped. it was a jerastic improvement. I let a few of my buddies drive it around and one of them just started bustin up laughing and went online and started looking for some for his golf.
No mark it was NOT all in your head.
- onlytrueromeo
I know for a fact the front one worked amazingly, I also know on the RS the back one worked amazingly when I had it preloaded slightly. I now have the corksport ones, and they're both neutral. Even if the effects were minimal, they are not that expensive to achieve that minimal feel. I don't know what they do for times but the front definitely increased turn in response.
