shouldn't I be using high temp red rtv since it will be mated to the engine??wytbishop wrote:use your finger to apply a very thin film of Super Black silicone RTV to all mating surfaces. It will seal very well, the downside is it will destroy the gaskets if you ever take them off.Mooneggs wrote:what should I seal the phenospacers with? the set comes with a gasket for each side... is there anything else I need to do?? rtv??
I guess for the IM side I could use black since the pheno spacers will not be transferring heat
