Advice on a wheels needed...
MrMazda92
Re: Advice on a wheels needed...
Post by MrMazda92 »
Youdirtyfox,
Are you running coil overs? What is the diameter of your strut/coilover body at tread height?
youdirtyfox
Post by youdirtyfox »
Yes I am. At tread height is the spring and the tire/rim is about 40mm away from it.
(That is with 15x8 ET15 195/45/15 btw @ -110mm)
AaronTietje
Post by AaronTietje »
A 16x7 or 17x7 with a +25 to +35 offset should bolt up with no issues on the body or suspension.
Also, 205 45 16 are super close height wise to a 205 40 17.
Are you planning on a lower suspension??? 15's can be made to look sick on these cars as well......slammed right down.
Correct me If I'm wrong on my offsets anyone........
benyandthejets
Post by benyandthejets »
AaronTietje wrote:A 16x7 or 17x7 with a +25 to +35 offset should bolt up with no issues on the body or suspension.
Thanks for your input. I am planning on lowering it with the eibachs eventually(probably a month or two).
93 Blaze Red GS
Ryan
Post by Ryan »
Look closer to +40 and +30 than +20 on 7" and 8" rims. With too great offset you can always run spacers.
Stock offset on a 15x6 is +45, to maintain the distance from the strut to the rim you want to subtract 12mm for every inch wider you go.
benyandthejets
Ryan wrote:Look closer to +40 and +30 than +20 on 7" and 8" rims. With too great offset you can always run spacers.
So from your rule then 7" would be around +33~ and 8 would be +21. I think I'd like to avoid using spacers as much as possible. Thank you for the information
93 Blaze Red GS
