Sealed, Deep Cycle AGM batteries
Re: Sealed, Deep Cycle AGM batteries
Truck's been running a Yellow Top since before I jointed the army, but in Quebec, we hit -20 for a few weeks straight. It hit below -30 for a few days, but I wasn't there at the time, so I can't tell you for -30 and below, but -20, no problems here.
Silkwyrm
Post by Silkwyrm »
Hey I realize this post is old and you probably got a new battery for future reference though, I went through a couple Red Tops. Eventually did some research on them. Chances are they aren't really dead. My MX-3 has a slow drain on the battery I'm still trying to track down, in the process of of figuring this out I've completely lost the charge on my batteries. First two times I thought the batteries were bad because when I took them to Autozone to charge them they said the battery was bad. Since it was still under warranty, I just got replacement batteries. The last time it happened the warranty was expired. I couldn't believe the amount of problems I have had with these supposedly awesome batteries. So I did some research and found that most battery chargers don't work right with the Optimas, something about not reading enough of an initial charge after a certain amount of time and then just shutting down reading the battery as bad. The fix is to hook up another good battery in parallel with your Optima and then leave it on the charger for a few hours. Then switch to just the Optima till it has a full charge. So I figured I couldn't tell Autozone they were doing this wrong and needed to hook up another battery to mine. So bought a cheap battery charger from Harbor Freight hooked it up with the battery from our other car and the redtop. Did exactly what Optima said to do, and sure enough it took a charge and has been working ever since, and this is a battery Autozone assured me was bad. So even if a shop tells your Redtop battery is bad, try this. Hook the Redtop up to another good battery with jumper cables positive to positive, negative to negative, then hook up the battery charger to the Optima. Let it charge for about two hours. Then remove the other battery and just charge the Optima.
