New ECU = new fun :) / Now with FAN ISSUE
Re: New ECU = new fun :) / Now with FAN ISSUE
Post by Josh »
Yeah I played around with them and unplugging that one definitely does that :/ I have narrowed it down to the 3rd sensor I just need to change it now :) They are so cheap I should probably grab the others as well, but they look new.
mikeinaus
Post by mikeinaus »
have you tested them in water? steps are in the manual and pretty straight forward. you measure resistance at certain temps. i played around with a few different temp sensors i had laying around and i had a couple that were good until they got to like 60 or 70C+ then the resistance dropped to nothing. if there in spec theres no point in replacing and its a simple test if you have a thermometer and voltmeter
