what do u want to know?
brands of what? turbo, ic, bov, wg, pump....
klze and turbos
- johnmx3ze
Re: klze and turbos
- MrMazda92
Re: klze and turbos
I understand the motivation, and I applaud it! I'm just saying you'd answer your questions much better by reading the book. It's in e-book form as well I believe, I remember seeing a PDF of it bouncing around a while back. You'll be asking hundreds of questions over a period of months if you don't read the book, as opposed to reading it in a week or two and asking supplemental questions afterwards.mazdaman222 wrote:thats why im asking so i dont break anything expencive
Good luck!
MM92
Re: klze and turbos
ok thanks and i found maximum boost online. and i was thinkin brand names for the bov fuel management injectors wast gate intercooler pipeing fuel injectors fuel pump wideband o2 collector pipes engine management better clutch stiffer engine mounts exhaust spark tuning
i need the specs that i need and where to get them ex.websites etc and i think the turbos are like t5 turbos i dont no how many mm's they are
- johnmx3ze
Re: klze and turbos
tell me how much money you have and ill give you brands....
Re: klze and turbos
i was gunna buy stuff as i go and wate till i have everything to do it, and i want some fairly inexpencive but still fairly good parts because im not really in a big rush to do it and they are pretty small turbos so i dont no if that will change much or what
