Page 2 of 3
Re: new twist....jeez
Posted: May 29th, 2011, 3:33 am
by Inodoro Pereyra
Hmmm...never heard of it.
Where do you hook it up?
Posted: May 29th, 2011, 5:57 pm
by Haley
Ok so heres what happened....
Managed to get the sensor changed...bit of a nightmare because when putting the bolt back in it broke....
anyway...its done.
So today I start the car up, no codes, but idling and revving like crap....misfiring I think. I can hear little poofs from the exhaust. I take it for a short test run, runs ok but not great. Get home, sit in the driveway listening to it sputter...
Its smooth if I gently roll on the accelerator, but if I give it a bit of a kick it sputters.
Checked the plugs, they are ok at the tip but oily on the threads.
Could this be because the ecu needs a long run to get used to the new settings (from a working sensor). My question mark doesnt work so bare with me...
And a question...to change the spark plug seals do I have to take the valve covers off.
I cleaned the disty connectors, but they looked spotless to begin with.
Posted: May 29th, 2011, 6:31 pm
by mxmikey
The seal for the spark plugs is part of the valve cover gasket, so you do have to remove it, if oil is on the plugs that would prevent it from firing correctly.
http://cgi.ebay.com/ebaymotors/SNAP-MT2 ... 645wt_1165
That is the adapter for Mazda OBDI it hooks up to the diagnostic box, behind the battery and it fits over the half towards the passenger side. The other part of the adapter hooks up to the scanner, and there is a little port on there for the a jumper cable to hook up to the battery (not until OBDII did the ports receive power for scanners). It is extremely hard to find pre OBDII scanners Asian scanners outside of ebay. Also sorry Haley for bringing your topic off topic.
Posted: May 29th, 2011, 7:54 pm
by Inodoro Pereyra
Thanks Mickey.
Haley: what you're describing sounds a lot like a vacuum leak to me.
Now, that may mean you're either very lucky, or very unlucky.
First, let's see if you're a lucky girl. Reach in the back of the air filter box, right underneath the accordion tube. You should find a small vacuum hose connected to the box. If it is connected, disconnect it and check it for cracks, and connect it back. If it's disconnected, connect it. See if the engine is running properly.
If that's not the problem, your luck may have just run out. Sorry.
There is a way to check for vacuum leaks using propane. I'm personally not a fan of it, but it does work, if you do it properly. It implies running a propane source (could be a lighter, or a propane torch) leaking propane along each vacuum hose, with the engine running. The engine will rev up when you hit the leak.
I'm personally more a fan of just replacing all the vacuum hoses for new ones. Now, here's the bad news: There's
19 ft. of vacuum hose in a K engine (ask me how I know
), and most of it is very inaccessible, either in the back of the engine (between it and the firewall) or underneath the intake manifold. There's also a little plastic container underneath the IM (right between the intake runners). BE VERY CAREFUL with that container, as its fitting cracks very easily, and the hose that goes to it is usually rock hard.
Either way, if you're careful, you shouldn't have any major problems. It took me about 4 hours to replace all the vacuum hoses in my MX-6 (including several trips to the auto parts store), so make sure you have the time before you start. And try to find somebody to give you a massage after you're done. You're gonna need it.
Posted: May 30th, 2011, 7:40 am
by Haley
So I checked my plugs last night, a couple were not in tight enough, so tightened them up. My negative battery connector was loose also, needed a new bolt and nut...did that, got her nice and tight.
This morning I was paranoid about driving it but figured I had to take my chances. ....ran like a charm, no cel, no stuttering, no problems.....
ahhhh...relief.
The only thing I"m concerned about now is the plugs. Oily around threads and white at the tips...like new plugs...maybe running too lean.
The guy I bought it from had put a k and n filter in it, so there is no top to the air box, is the cone filter. So I'm thinking its getting too much air, not enough fuel cause of that. is there a simple adjustment I can do (ex: air idle screw)?
You guys are the best...couldn't have done this without you!!
Posted: May 30th, 2011, 8:56 am
by Haley
Yes, his analyzer thingamabobber is a snap-on with adapters for different makes.
Not that it matters now, but just fyi. They do exist.
I'm sorry, I cant remember everyones names yet, but to the guy who mentioned about leaving the wire in the diagnostic box...yep...did that at one point, but took it out shortly after. That was a real 'DOH!" moment.
Ahhh...live and learn...I'll pick up the quirks of these little cars soon enough. The engines are in there so tight, hard to get to a lot of stuff but where theres a will theres a way.
Posted: May 30th, 2011, 8:59 am
by Inodoro Pereyra
So now it's running ok? If it is, don't touch it, unless you see a symptom that something is gonna go sideways soon.
You say the spark plugs are white "like new". What do you mean? Can you post a pic?
If they're not corroded, and the porcelain is in good shape, I'd leave them alone. Don't worry about the oil on the threads. As long as you don't have oil inside the cylinder, you're ok. Later on you can change the valve cover gaskets, if you feel like it (if you do, read Ryan's post on replacing the friction gear springs before you do. I'd highly recommend you to replace them when you open the valve covers, so you don't have to do the job twice, if they fail later).
Finally, don't worry about the K&N filter, the ECU should compensate for the extra air (that's what the VAF is for). Just remember to wash it every now and then.
Posted: May 30th, 2011, 9:28 am
by Haley
I mean the plugs look like they were just put in....the ceramic is still white.
I figure I'm going to leave the valve cover gasket for later, its not leaking or anything so I'd rather just leave it alone. Like you say, its running good, leave it alone. Just dont want it to seize on me cause its too lean.
The guy I bought it from did say the plugs and wires were new, so really they've only got a few thousand km on them.
Posted: May 30th, 2011, 9:49 am
by Inodoro Pereyra
Don't worry then. Shiny plugs (and especially white porcelain) mean perfect combustion.
For once, the guy who sold you the car didn't lie. He did put new plugs in it.
Posted: May 30th, 2011, 9:55 am
by Ryan
All I have to say is, your level of awesome raises the bar for other females.
My girlfriend doesn't know which way a spark plug goes in, nevermind that there is ceramic involved. Good thing I don't have any expectations of her becoming my mechanic
Posted: May 30th, 2011, 10:51 am
by wytbishop
Loose ground post...that's wierd.
Posted: May 30th, 2011, 10:56 am
by Haley
Aww...thanks Ryan.
Yeah, I had my own motorcycle shop a couple years ago, can take a bike apart and rebuild it fairly easily.....but cars...I'm just learning.
But the basics are the same so it helps.
I'm a single mom, with a not so good paying job so I cant afford to have a shop do the work for me....have no choice but to learn to do it myself....thank god for the internet and guys like you!
Posted: May 30th, 2011, 9:29 pm
by tripleMX-3chicMS
so mxmikey & Haley both have GS SE's???? I need pics... ( :
De
Posted: May 30th, 2011, 9:43 pm
by Daninski
Haily you can try snugging down the valve cover bolts a little as over time the gasket looses it's flexibility. Remember I said just snug and follow the manual for proper 'snugging' pattern.
http://www.mx-3.com/manuals/showimg.php ... B2-032.gif
Posted: May 31st, 2011, 7:45 am
by Haley
I'm not sure mine is an SE....??? Dont the SE models have leather interior? Mine doesn't. I have all the other bells and whistles, air, cruise, moonroof, power everything....but cloth interior. How do you tell?
I will check the valve cover bolts...thanks for the link!
My bigger issue right now is the original problem before my crank sensor went.
The idle is crazy. Its ok for a while, but after driving for a while (1/2 hour or so) it revs up to 3 grand if its in gear even with the clutch in at a stop, and if I take it out of gear, it bounces from 1200 to 2000 up and down until I start moving, then jumps to 3000. I dont even have to touch the accelerator and it goes. Once I get it into about 3rd gear and give her a bit, she settles back to normal....until I stop again.
How weird is that? I"m actually wondering if it is clutch related.
Any ideas?
Annoying cause its running great other than that.
