Page 2 of 2
Re: MX-3 V6 97 will not start!
Posted: September 17th, 2010, 10:04 am
by ninjajim4
RS_OBD'oh_2 wrote:The only issues you can have with a spark is voltage and resistance.
Get a multi meter and check resistance of your wires end to end
You should also be OBDII, do you have a check engine light, or a code reader? If not, well worth $200.
if you have a laptop, get an OBD interface for 30 bucks instead.. a little shocked that the handheld readers havent gone down more in price given how cheap the USB readers are
Posted: September 17th, 2010, 1:58 pm
by Inodoro Pereyra
Where? I didn't know you could get such things. Ebay?
Posted: September 18th, 2010, 8:42 pm
by Daninski
I bought this one, works great. Once you load the software and figure out which comm to use your all set.
Here's what the software looks like.
viewtopic.php?f=46&t=65550&hilit=daninski" onclick="window.open(this.href);return false;
Posted: September 18th, 2010, 9:54 pm
by RS_OBD'oh_2
wow, that's quite impressive. That would help with tuning too.
Posted: September 18th, 2010, 10:16 pm
by Inodoro Pereyra
That's scantool. I've heard of it before.
But what interface are you using, and where did you get it?
Thanks for the link. I hadn't seen the scantool screen before. Looks good...
Posted: October 17th, 2010, 6:35 am
by PDP
I tried to jump TEN and GROUND and turned ignition on, but there was no light at all at the CEL. Wonder why? Any has any link to a reader i can use to the mazda mx-3 v7 1997 model? Handheld or a USB connector to use with an computer?
I have no ide what it can be now, i have decided to try to order a new disty, my type is K834 TOT57171, but i do not know if this will help. Since when i try to crank the engine it does not give ANY sign of that it is trying to start, its only going round and round on the starter..... And the spark is yellow...
Posted: October 17th, 2010, 10:31 am
by Ryan
If it does spark, don't replace your disty just yet.
If you're getting spark, your timing belt is good too. It may have jumped, but its still intact.
Check your fuel pump...
Turn your key to ON, and open the DIAGNOSIS box under the hood. Jumper F/P and GND and listen for the pump coming on. You should also hear to fuel running past the fuel pressure regulator, you should know for sure if it comes on.
Posted: October 17th, 2010, 10:55 am
by PDP
I tried to jump the F/P and GND but i could not hear any fuel pump sounds. But when i try to crank the engine the pump maked noise!
Posted: October 17th, 2010, 11:19 am
by Ryan
Did you have the key in the ON position?
Posted: October 17th, 2010, 2:00 pm
by PDP
Yeah, i turned the key around after i had jumped the F/P and GROUND
Posted: October 17th, 2010, 4:03 pm
by Daninski
Soft codes won't show, only hard codes.
