Loud noise...need a second opinion
- _-Night-Shade-_
Re: Loud noise...need a second opinion
Yeah I've got one of those magnetic camber/caster gauges that you can stick onto the hub/rotor. I'm able to set the camber back to what it was whenever I have to take out my camber bolts, but I didn't know what to do for toe.
measureing tape method works reasonably well. There are lots of bolt on toe plates on the market to make it easier to measure. OR you could just build a pair of toe plates out of flat bar or angle iron.
- Dragon1212
Could this be my problem as well.
We think its the passenger side CV joint. Just because its hard to hear it is the thumping noise in the back ground. At 3:34 i turn on the highway and you can hear it. Till then its just the usual sound of the car.
Worklog for the Blue One
Worklog for the KLZE
First Car, And My baby... $550 To buy and repair from Write-off... The radio and amp that was in it was worth more than that!!!.
Hunting For a Supra MKIV, but I'll never get one. Still Hunting.
- Dragon1212
Guys I need a opinion its getting worse and I believe that that is the problem I just need to know if it makes sense that that would be the problem.
Man I had the same problem, clicking. Turns out my dentures were cracked on the right side but it sounded like a brake issue. Insurance paid to have new ones made.
I could not really make out the sound you're describing in the video. In general, if you hear clicking when the wheel is turned it's usually a CV joint. A "whirring" noise is usually a wheel bearing.
I would start by removing the axle and inspecting it carefully. If the boots are cracked and so on that's a pretty good sign that they've been unlubed for a while and are likely to be pretty worn. They are pretty easy to replace as well. The bearings are a little bigger pain in the arse.
