how to fix peeling clear coat?
- mitmaks
Re: how to fix peeling clear coat?
Put one coat of paint, wait 5 mins, put another one and after another 5-8 mins put third one. Wait an hour for paint to dry and put 3-4 coat of clear. Always put tack coat (dust coat) of clear on first, spray the following coats on wet.
- Ryan
as in, do that process 3-4 times?
400 grit for regular paints 600 for base coat paints. You have to wait a while sometimes a month before wet sanding it smooth or waxing. Do a little research, ask for manufacturers instructions.
mikeinaus
intresting... i was going to wetsand the clear a few hours after it dries. theres no instructions on there website and they dont say what the paint/clear is made of to really research much
- mitmaks
Best to leave clear coat sitting at least in 75F weather for a couple days before you wet sand it.
You want to put 3-4 coats of clear, meaning you will spray one coat of clear, let it flash for 5 minutes and then follow with the rest, allowing 5-7 minutes between each coat.
mikeinaus
yeah i fucked it up lol. i sanded too soon and faded the paint in some spots. fairly easy to fix but i cant be bothered. its only noticeable in the shade anyways. put on another 3-4 coats of clear. when its dry its going on the car. it looks way better then it did and its already nicer the then the rest of my car.
