Page 2 of 2
Re: Front end clunk when steering & and hitting a bump
Posted: June 28th, 2010, 11:16 am
by valentiner
Recently had similar symptoms on my '90 Geo Storm. Turned out my NOS CV's failed almost immediately (ripped/torn boots) and was getting the clunking when making narrow turns, either side, they both failed approx same time. I had replaced EVERYTHING but the smaller/front control arm bushings, but they did not seem loose. For longest time i didn't even get my head around behind the steering knuckles to check my boots because they were FRIGIN NEW! But indeed, the used set of CV's i had sitting around solved my clunking...
Posted: October 1st, 2010, 9:13 pm
by bbunkerc397
Already fixed the problems I put new upper strut bearings and and strut mounts and problem fixed. thanks anyway
Posted: November 8th, 2010, 2:51 am
by MrMazda92
bbunkerc397 wrote:Already fixed the problems I put new upper strut bearings and and strut mounts and problem fixed. thanks anyway
I was going to double suggest checking the strut mount, I just fixed this exact issue on the '98 Toyota Camry my girlfriend drives. Clunking while turning, especially when it's cold out; I popped the hood and bounced her up and down a few times, saw a 1/8" gap between the right front mount and it's strut, that bounced up and down with the car. 1/2 a turn tighter, problem solved.
