Page 2 of 2
Re: Obd 1 or 2
Posted: April 18th, 2010, 5:57 am
by umcamara
If you have any idea what he's doing then it may work. The LED can work, I believe, even if the CEL doesn't work. I think there's a procedure for which pins to jump for the LED.
Probably time to start searching the forums at this point...
Re: Obd 1 or 2
Posted: April 18th, 2010, 7:46 am
by DeepBlueMX3
umcamara wrote:If you have any idea what he's doing then it may work. The LED can work, I believe, even if the CEL doesn't work. I think there's a procedure for which pins to jump for the LED.
Ok man, at this point, I just know the the error codes(paperclip 4cyl faq, thanks), and the conections for the LED and Jumper,
LED ===> negative(FEN), positive(B+)
Jumper==> TEN and GND
Tomorow I'll test then!
Thanks !
Re: Obd 1 or 2
Posted: April 21st, 2010, 3:51 pm
by DeepBlueMX3
The LED works fine, like in the youtube video!
Thanks to Ryan and Umcamara !
Re: Obd 1 or 2
Posted: April 28th, 2010, 12:29 am
by ramsen25
Is it still 2 oxygen sensors for the obd1 mx3
Re: Obd 1 or 2
Posted: May 4th, 2010, 12:44 pm
by DeepBlueMX3
ramsen25 wrote:Is it still 2 oxygen sensors for the obd1 mx3
I only know about one sensor, called "lambda".
