Page 2 of 2
Re: High fuel consumption
Posted: January 17th, 2010, 4:50 am
by arendal
Okay, i have three sensors, ill post a pic later...
Again i tried to read out fault codes, and now the car report fault 15, bad o2 sensor. So i will bye a new one.
Posted: February 2nd, 2010, 1:56 pm
by MugenReplica
So, have you fixed the problem and has your fuel consumption decresed?
Posted: February 7th, 2010, 6:52 am
by arendal
No i stille have the problem, i try change the o2 sensor, but dident change 2 much. But i dont know if there could be a problem with the new o2 sensor? The readings i get when i meassure it seems to be wrong, it says only 0,001 volt and do not change at all....
Posted: February 7th, 2010, 6:53 am
by arendal
But i dont get any fault from the ecu anymore.
Posted: February 7th, 2010, 5:24 pm
by fowljesse
Have you checked the MAF voltage?
Posted: February 10th, 2010, 10:06 am
by arendal
I also have problems with the idle, when it is cold, it run about 2000rpm, when it get hot it fall to 750. But when i drive a little trip, and stop for idle it goes up to 1100 and dont go further down.... If i start and stops the car the idle is perfekt 750... If i rev the engine it falls back to 750. but if i drive again, then it goes up to 1100rpm... If i put it in gear and slip the clutch a little, so then engine falls under 750, and the take the clutch fully agaĆn, it stabilise to 750rpm again...
Could this problem be related to my high fuel consumption??
Posted: February 16th, 2010, 11:33 pm
by Newfie_dan
mine does that when its really cold out, I have not found a source for it as of yet but if I do I will post it.
