where is crank position sensor on 1993 mazda mx-3 1.6 litre
gonenutz14
Re: where is crank position sensor on 1993 mazda mx-3 1.6 litre
ok yeah the fuel is comming outta the injector i pull the injectors out to see if they were spraying they are but the car runs like dog poo now runs real rough like a major misfire but i changed everything and replaced with knew and even switched again to see if the plugs where bad still runs real rough and sensors at all able to make it do that ?
- Ryan
you're impossible. I gave you a nice list of s--- to try, and you go an disassemble your fuel rail like a tard. I'm not helping you anymore.
gonenutz14
nah it was already takin off and put back on lol
i went threw everything im not knew to this but the electronics i am lol i built the mx3 it was auto its now standard but i just cant figure out why it started runnin like this for no reason lol i took the injectors off a yesterday to see if it was working or not cause thats what i thought to begin with maybe the injector went bad but nope it didnt lol still works i checked everything on why it was running like that but i havnt found the problem yet
