Re: timing belt problem HELP
Posted: June 24th, 2009, 8:58 am
melb30x wrote:As a rule of thumb, everytime your car needs a replacement timing belt you should also replace the tensioner - hence all the timng belt kits available.
Ive seen cars where the tensioner was put on the reverse, causing the tensioner to rip into the belt and make it shudder. Im not sure if this is possible in our cars as i havent done my timing belt yet, but i would say it is.
if you havent touched the tensioner, you probably should - it's a good place to start, and i would say if you're replacing the timing belt, tensioner should def. be new too.
Good luck.
melb30x
With our cars, it is next to impossible to install the hydraulic tensioner upside down. If you mean the tensioner pulley, then even that is next to impossible since any person with enough knowledge to perform a timing belt change should have the common knowledge of how to reassemble everything that is taken apart.
Sure it would rip into the timing belt, but you would immediately notice that the tensioner pulley was installed improperly before everything was put back together. I don't think that is the case here.
mazdapr, the tensioner pulley will pivot on the axis of the allen bolt. Are you saying that the bolt is too tight making it so that the pulley does not pivot? It should pivot, otherwise you may have forgotten to put the washer back in (between the pulley bracket and the block). Take a look because it could be pushing your belt closer to the engine this way (causing it to rub against the block).
