KLZE: blue smoke after motor braking
mx-3_4evr
Re: KLZE: blue smoke after motor braking
Post by mx-3_4evr »
What ECU are you running?
MX-3-Tom
Post by MX-3-Tom »
I drive the ECU KL31 with manual tranny.
http://www.mx-3-tom.de" onclick="window.open(this.href);return false;
http://www.mx-3-community.de" onclick="window.open(this.href);return false;
SWAP COMPLETE: B6 DOHC (16V) --> KL-ZE (24V)
Post by wytbishop »
It's very hard to be sure what the problem is without a leak down and compression test. If you're really concerned about it I would have that done. It will make it much easier to decide what to do when you know for sure what is wrong.
MX-3-Tom
Post by MX-3-Tom »
Normally the compression and leak down test should made yesterday.
Now the car is atthe painter because of the ne front bumper.
So the test is going to be made on monday.
MX-3-Tom
Post by MX-3-Tom »
Hi!
I got the results of the compression- and leak down test.
The compression was very good. Approx. 12 bar on every cylinder.
And the leak down test showed also no abnormalities.
