Page 2 of 2
Re: supercharged 1.6 sohc
Posted: May 14th, 2009, 8:32 pm
by Nd4SpdSe
Eaton M45
http://www.capa.com.au/eaton_m45data.htm" onclick="window.open(this.href);return false;
5psi takes ~5-10hp
10psi takes ~10-20hp
Posted: May 15th, 2009, 10:06 am
by nos92mx3
projectzemx3 wrote:however the post about the engine only having 88 horse stock so if you added low boost for safety, would only bring it up to 130 made me laugh so hard.
the best power mod you can make out of your b6 powered mx3, is to remove the b6.
how do you figure?
Source a turbo manifold, small framed t3 (.42 or .60/.48), 14b, something maybe a bit larger, and a decent fuel setup/method. (safc and bp26 or megasquirt) run moderate boost and make 200 fwhp.
sure boost wont come on till 2500 rpms, but who drives their car around below 2500 rpms.
I look at it this way with how short our trannys are geared and my hybrid turbo, boost is a gear away.
Posted: September 16th, 2009, 8:45 pm
by ManNinco15
There is really no point in supercharging a 1.6 sohc. Sohc is an automatic swap, no questions asked. Then save some money up and turbo that sonuvagun!!!
