okay i need help
kego
Re: okay i need help
Post by kego »
like motor running???
SuperK
Post by SuperK »
Don't use the negative battery connection, use the "grd" pin.
Keep the motor off, but turn the key to "on" position. Don't start the car.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
kego
Post by kego »
the code was 34... idle air control valve?
Ryan
Post by Ryan »
Yessir. Its the turbo shaped sensor that is fastened to the bottom of the TB.
I have a pic somewheres.
the blue.
kego
Post by kego »
wouldnt that just mess with my idle?
Ryan
Post by Ryan »
Well, it allows air through that isn't controlled by the actual throttle butterfly...
Are you sure thats the code?
long long long (slight pause) short short short short (longer pause, repeat)
kego
Post by kego »
i am sure thats it... but usually the delay happens when i start out and at wot... couldnt the studdering at wot be attributed to the iscv not opening and keeping the engine from max air intake? does the valve even open at wot? because in theory, and i don't know the size of our TB's so bear with me, if our TB's are say 55mm and the valve opens at wot to pass air under the butterfly gate, and the valve doesn't open at wot, could the studdering be a lack of air being passed under the butterfly gate?
nos92mx3
Post by nos92mx3 »
Possibly a vacuum leak at the Idle air valve? that would throw off the MAf readings...
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
kego
Post by kego »
the thing it that it started doing that after i messed with the vaf and although it's significantly better that it was, the problem remains. and the car ran fine before my vaf got messed with. i dont think it would have been a vacum leak because it had previously worked fine and it just seems too coincidential that the original cause got fixed and at that very second a vacum hose decides to crap out causing the same problem. unless the vaf problem i was working with caused a vacum leak? which hoses should i take a look at?
SuperK
Post by SuperK »
get a replacement vaf.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
nos92mx3
Post by nos92mx3 »
every hose in the intake system after the maf
93' Rs-t BPT - Sold
kego
Post by kego »
i already replaced the vaf 3 times and the problem in the video is not there any more but now when i got to start out, unless i rev it i occasionally stall... so now i have an idle problem
Ryan
Post by Ryan »
Where does it sit at idle? I like mine around 1k. Its a bit high, but doesn't rumble as easy...
I've noticed my BP is prone to rumble :? Then again, my old SOHC used to idle around 2.1k most of the time :lol: maybe I just need to learn how to drive. :lol:
You can adjust the idle, there is a writeup. I'm too lazy to search for you.
kego
Post by kego »
its not even so much the idle really it idles at 1500 which is cool with me but when i let out the clutch where normally it would slowly accelerate to 5mph, it chokes and dies. P.S. i do know how to drive stick. but i'm forced to rev to about 2500 to get the car moving. i shouldn't have to do that. the car almost forces me to gun it
kego
Post by kego »
[quote="Ryan"]
Image[quote]
why is there a bolt on the butterfly gate?
