Re: Bad Idle When Pushing Brake
Posted: February 15th, 2009, 10:06 pm
I had bad troubles with Idle that would get worse if I had the A/C blasting. I would almost stall.
I found out that my fuel filter was bad, and being an idiot at the time did not know they needed to be changed every year. So if you have not changed your fuel filter I would recommend doing this. It fixed up my idle
