I found out that my fuel filter was bad, and being an idiot at the time did not know they needed to be changed every year. So if you have not changed your fuel filter I would recommend doing this. It fixed up my idle
Bad Idle When Pushing Brake
Dark_Rider2k3
Re: Bad Idle When Pushing Brake
I had bad troubles with Idle that would get worse if I had the A/C blasting. I would almost stall.
Idle screw on top of the TB not the allen key one with the locknut. That's factory set.
