Page 2 of 2
Re: Clutch problems....I suck
Posted: August 12th, 2008, 6:44 pm
by onlytrueromeo
EDIT, I figured out that white thing is the neutral safety switch. So Now I just need to adjust pedal stuff. I will attempt that now.
Posted: August 12th, 2008, 7:11 pm
by onlytrueromeo
UPDATE
I GOT IT TO WORK! I think at least. I need to wait til the car is lowered to the ground now...I had to adjust the pedal play.
Also the safety switch was broken, so to fix it, I jammed a screw in there...yeah I know its not a safety switch no more but I'll be fine.
Posted: August 12th, 2008, 7:54 pm
by Mooneggs
onlytrueromeo wrote:Also the safety switch was broken, so to fix it, I jammed a screw in there...yeah I know its not a safety switch no more but I'll be fine.
mine is broken as well and I have to manually press it with my hand to start the car - maybe I'll try your remedy :welder:
Posted: August 12th, 2008, 8:32 pm
by onlytrueromeo
I used a 1/4 or something and just threaded it in there (not forcing it, the threads fit PERFECT into the hole).
Mine was broken like 1/4 inch ouch from it, so I just pushed it in the rest of the way w/ the screw. If you have more sticking out then that, you will prob. need to break it off shorter so you can get a screw in there.
I have more of the screws I used if you would like me to mail you one in return for stuff you mailed me :-P
Posted: August 12th, 2008, 9:06 pm
by npspears
Glad you fixed the problem. I took these pics a few hours ago but had to sit in a meeting so just been able to load them up. Maybe they will help.
Posted: August 12th, 2008, 9:16 pm
by onlytrueromeo
Hey that does help- I know what I;m missing....thanks!
Posted: August 12th, 2008, 9:52 pm
by Daninski
If you need a part let me know. I have a 92 ready for scrap. Clutch linkage works perfect. (now for the deluge of requests for parts, aaaarrrrgh.) You pay shipping but if it's a pain to remove, you owe me,,,,something.
Posted: August 12th, 2008, 10:04 pm
by onlytrueromeo
well...if you want to send me the neutral safety switch...sweet. But I figure having a car that starts like an automatic isnt bad either (I push the clutch in anyway)
I'll hafta wait a week either way since I'm moving back to college.
Dude...the ze kicks a--, even running rich, idling terribly and smoking.
I barely let off the clutch to test if it was moving and it just wanted to launch me into my shed...lol good thing I installed my brakes right...
