can someone post a pic of the diagram for the cel?
Mine lost the cap . i know by memory which ones are ten and ground but I dont know which one is fen.
Installed kl36 ecu. Rad fan always on??
Re: Installed kl36 ecu. Rad fan always on??
-hec
- 94mx3precidia
are you sure about this? i dont really want to be sticking wires and pins into random places to see what happens.shameem wrote: The led goes between FEN and B+ and the jumper goes between TEN and GND.
Have you just read about it or have you actually done it yourself?
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
I have done it myself - its like a replacement for CEL ..... But it was on a stock 94 4 cyl - i dont know if it will work for your engine/ecu combo
![Image](http://img517.imageshack.us/img517/5927/fliegetn0ss7.gif)
- 94mx3precidia
well i tried the FEN and +b with ten and gnd and no go. the led didnt even light up. i guess the only way i can get codes is if i switch the ecu's and go for a drive.
