over heating..
Re: over heating..
check your plugs, make sure that there is no coolant on them. i had the same problem. car overheated only when i pressured it. i could drive around normally without any problem. checked to make sure coolant was flowing to eliminate the water pump, changed thermostat, changed radiator caps, filled the system to make sure that there was no air and sure enough when i checked my plugs, # 3 and 5 had coolant on them. interestingly when i did a compression test those two cylinders had the higher compression (170's vs 150's for the rest) likely because of some water (coolant) in the cylinder. not saying that its a head gasket, but sometimes it can be subtle.
1993 MX-3, KLZE, HOTSHOT HEADERS, CUSTOM EXHAUST WITH WALKER QUIETFLOW, K&N INTAKE, DIGITAL 6, QUAIFE LSD, FIDANZA FLYWHEEL, CLUTCHMASTER STAGE 3, GROUND CONTROL COILOVERS
14.32 @ 95.4mph
14.32 @ 95.4mph
Re: over heating..
ok ill check them....but the fan comes on...and i only have one ? lol...but i will try and bleed it for longer then i have been...
thanks..ill let you no whats up
thanks
and whats the deal with the garden hose ? why would i put a t in one of the lines?
thanks
Re: over heating..
Just to burp the system better, if you sit there after its been up to operating temperature it should be fine, give it a few little revs and it should be good.96mx-3 wrote:and whats the deal with the garden hose ? why would i put a t in one of the lines?
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
- umcamara
Re: over heating..
The deal with the garden hose is, some people cut one of their coolant lines going to the heater core, then install that plastic T. Then they plug the garden hose into the T, turn on the water, open the rad at the bottom, and run the engine. This forces clean water through every part of the cooling system to flush it.
Re: over heating..
well its ah ead gasket or crack in my block lol..i guess maybe i didnt torque them down in a proper sequence..and the book only said 19ft pounds but ive been told that seems low lol...any tips on tightening head bolts?
Re: over heating..
a head gasket would be a hell of a lot easier to deal with than a cracked block.
as far as the torque specs the initial torque down is 19 but then you torque in sequence another 270 degrees (i can't recall exactly) which takes the total torque a lot higher.
14.32 @ 95.4mph
14.32 @ 95.4mph
Re: over heating..
yea that was my problem i think...cause i did it to..17 ft..then 18..then 19..
but like 2 90deg. turns it says in book..canges the ft pounds huge..but w.e simple mistake i guess..jsut along fix process..
Re: over heating..
well i got it back..and its head gasket..what i did was tightin in 3 steps from 17-19 not then adding two sets of 90 turns..so my friend said i could jsut make sure there at 19ft..and then add the two sets of turns..so i have done one set..and it makes a terrible noise kinda makes me nervus to do a whole other set...is this common or ?
Re: over heating..
what was the problem and how did you fix it?comish71 wrote:check your plugs, make sure that there is no coolant on them. i had the same problem. car overheated only when i pressured it. i could drive around normally without any problem. checked to make sure coolant was flowing to eliminate the water pump, changed thermostat, changed radiator caps, filled the system to make sure that there was no air and sure enough when i checked my plugs, # 3 and 5 had coolant on them. interestingly when i did a compression test those two cylinders had the higher compression (170's vs 150's for the rest) likely because of some water (coolant) in the cylinder. not saying that its a head gasket, but sometimes it can be subtle.
Never be afraid to try...amateurs built the ark, professionals built the titanic.
Re: over heating..
i removed the heads a week or so ago and didn't see an area in the gasket that was blown out. it wasn't like i expected to because the car only overheated when i really pressured it (moreso with the nitrous). one thing that i did find was that one of the head bolts b/w 3 and 5 cylinders was not as tight as the others. whether or not this is due to stretch from increased cylinder pressures or because of threads going in the block vs bolt i haven't found out yet. i need to take the heads to the machine shop so that they can be checked for warpage. i will then put everything back together and see how things work. as a reminder if one head needs to be shaved then both do to prevent increased compression on one side of the motor.
14.32 @ 95.4mph
14.32 @ 95.4mph
