Under this #MX6 88-92 255LPH HP GSS341-400-866
the application says "MAZDA MX6 88-92 255LPH HP"
For this #MX6 93-97 255LPH HP GSS342-400-730
the application shows "MAZDA MX6 93-97 255LPH HP"
Both are "HP" versions for the MX-6...
From the minutes on the pc, it seems almost every post about the applications for the MX-6 shows the WALBRO 255lph fuel pump and is sold this way...No mention of the 190lph fuel pump... I would assume looking under the MX-6 would be OK to use? All found posted application years are 93-97...Which is common to the KL-ZE...
So from the minutes online, it looks like the 255lph fuel pump is ok to use on the 2.5L...Still unsure if the KL-ZE is a diff ball of wax, but cant see it being much of a difference?? Very curious what the responces about this will be?? It's hard to belive everything on the internet, but for the sites i went to, aLL SHOW THE 255LPH WALBRO FUEL PUMPS IN USE FOR THE MAZDA MX-6?? hMMMMMMMMMM...Hopefully this is looked at again as it may change many members' fuel pumps in the near future if the 255L is ok to use instead of just the 190lph...Could anybody make a QUESTIONAIRE POLE like the 1 that asked "who owned thier car since new" in the past little while....Just to find out what pump most peeps are using...the 190lph or the 255lph fuelpump, if the mod was done that is...
WALBRO FUELPUMP OSS342 FOR KLZE
Re: WALBRO FUELPUMP OSS342 FOR KLZE
______________________________________
AUTOZAM
1992 MX-3 KL-ZE Brilliant Black w/SE interior
AUTOZAM
