i love cali
Dark_Rider2k3
Juans_93_MX3
If you guys do enough researching, espically on probetalk, you can find threads like these that help you out pass emissions.Dark_Rider2k3 wrote:This is making me nervous about swapping engines. I know PA is pretty relaxed compared to cali, but still....
Really, from what I have read, as long as your engine is in good shape (no bad piston rings), you do basic tune up, make sure your exhaust O2 Sensors are connected, CAT is ok and you make sure all the vacum hoses are connected and in good shape
You should be able to pass emissions
http://forums.probetalk.com/showthread.php?t=1701242736
http://forums.probetalk.com/showpost.ph ... stcount=10
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
