Car Died/Wont Start
Re: Car Died/Wont Start
I have the MAF off of the car.
The MAF sensor is off the car, all of the air intake black plastic things as well are off.
- kulluminati777
it could be possible the belt teeth stripped some and the timing is off
especially if its a cheap belt
Ok Thanks. I am going to check all that. I know the previous owner of this car had the top half of the motor apart as all the bolts are finger tight.... What a mess.
- kulluminati777
if its the vavle covers and intake u speak of they are torqued very light so it would seem hand tight... it is VERY important these are torqued to spec.
also check the hydraulic tensioner, it may have failed and let your timing belt get a tad bit loose and the teeth shimmed off
LivinDeadGurl wrote:The MAF sensor is off the car, all of the air intake black plastic things as well are off.
I dont think it will start with the MAF off. It should at least try to start....i think.
1993 Mazda Mx-3 GS-Sold ![Sad :(](./images/smilies/icon_sad.gif)
1992 GS "The Bucket" Gone.
92 GS 5spd for sale! Sold it....after I got a hatch cover in great condition![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
MY WORKLOG, check it out
viewtopic.php?f=46&t=79959
IF I try to start my B6 without the Maf plugged it will just stall out, if theres no intake that's a massive vaccuum leak and the car won't start unless you give throttle after it's turned on.
Timing was off. I guess the people who had the car before me, didnt do the timing correctly... We took everything apart, and redone the belt, and now it runs. Just dealing with sensors now. ![Sad :(](./images/smilies/icon_sad.gif)
Thanks to all who helped on this issue!!
Greatly Appreciated!
