Diesel KL info???
oh yeah its propane, he has some sort of stand alone.
-hec
dang does anybody have any info on the diesel?!
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
- Yoda
The 2.5L KL diesel as far as I can tell was only used in a limited numbers of small S.E. asian countries and only in a RWD configuration for use in small mazda commercial truck (not the B series) As I have more recently found that it is actually an offshoot of the Suzuki version of the K series engines.Nd4SpdSe wrote:I wonder if wise-old Yoda can help us out on this one...
If you are thinking Diesel I would consider the diesel version of the FE 2.0 used the the 323F (Protege 5) I have been talking to a guy in France for a few years now that is running over 310hp but over 500ft/lb torque all under 4500rpm in a 323F
WOW just think what that would do in a mx3!!!Yoda wrote:The 2.5L KL diesel as far as I can tell was only used in a limited numbers of small S.E. asian countries and only in a RWD configuration for use in small mazda commercial truck (not the B series) As I have more recently found that it is actually an offshoot of the Suzuki version of the K series engines.Nd4SpdSe wrote:I wonder if wise-old Yoda can help us out on this one...
What cars would have the FE diesel in them? That is a really interesting swap.Yoda wrote:The 2.5L KL diesel as far as I can tell was only used in a limited numbers of small S.E. asian countries and only in a RWD configuration for use in small mazda commercial truck (not the B series) As I have more recently found that it is actually an offshoot of the Suzuki version of the K series engines.Nd4SpdSe wrote:I wonder if wise-old Yoda can help us out on this one...
4 mx3 GS SOLD-
4 mx3 GS SOLD-
- fowljesse
How difficult would it be, and how would you keep from snapping axles?
Convert to AWD or RWD and build a chassis. AWD has been done on a MX3 before...fowljesse wrote:How difficult would it be, and how would you keep from snapping axles?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
I think his name was Josh but he had a 4cyl.teribble wrote:AWD Really does anyone have any pics or info? What did they swap in the mx3?Juans_93_MX3 wrote:Convert to AWD or RWD and build a chassis. AWD has been done on a MX3 before...fowljesse wrote:How difficult would it be, and how would you keep from snapping axles?
You would need a chassis, customs axels and a custom bracket or adapter of some sort to make a AWD tranny mate with a KL engine
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Re: Diesel KL info??? FE Diesel???
Custom axels? FE diesel mx-3?! IS it possible?
4 mx3 GS SOLD-
4 mx3 GS SOLD-
I know a guy on imazda.com that has done the AWD conversion. I think his name is projectmx. The conversion is crazy. but i bet its so worth it.
92 Blaze Red MAZDA Mx3 <GS> ZE, millenia manifold. gutted interior, filled mounts, fidanza fw, act 6puck.
Re:
Do you have anymore information on the motor, this is rather interesting as the block would have to beYoda wrote:The 2.5L KL diesel as far as I can tell was only used in a limited numbers of small S.E. asian countries and only in a RWD configuration for use in small mazda commercial truck (not the B series) As I have more recently found that it is actually an offshoot of the Suzuki version of the K series engines.Nd4SpdSe wrote:I wonder if wise-old Yoda can help us out on this one...
a lot more "beefier" to withstand the increased amount of CR required with diesel's ?
Information on the web is non exsistant for this beast, what is the Suzuki variant called?
Answers or tip's or just anything would be gladly appreiated Yoda.
- tehbrookzorz
This is from Wikipedia
"The Mazda K series was co-developed with Suzuki, with Mazda reportedly handling the bulk of the design. The early 2.0 L Suzuki H20A and Mazda KF are similar in design, but the two engine families diverged after this. Suzuki focused on building ever-larger torque-producing engines for their SUV lineup, while Mazda focused on high technology and power output. The later Suzuki and Mazda engines do not share many components at all."
Cody
