Page 2 of 2
Posted: September 19th, 2007, 1:59 pm
by zoom_zoom94mx3
haha, i wish!!! my guess is that it would be more like 30whp... not sure though because i cant find anyone who has actually got one.. I plan on buying one, but not until the spring when i am out of school and can afford to replace parts when i blow my poor little mx up lol.
Posted: September 20th, 2007, 12:49 am
by 45ryder
its for my race car and turbo is not allowed. i geuss i should also have mentioned its a SOHC and the only car beating me is a geo storm by .5 seconds per lap
Re: throtle body upgrade dohc
Posted: November 10th, 2008, 8:43 am
by OptiX
delete the fuel pressure regulator vaccum valve at the end of the fi harness (just unplug it and leave the rest if you're lazy, otherwise remove the valve too and just run a piece ov vacuum tube directly from the fpr nipple to the intake plenum nipple. thats how it is on the 8v versions, and is actually is creates a more responsive oem fpr)
Posted: November 13th, 2008, 7:39 pm
by cjthor
I will have a bored TB for sale soon. PM me for info!
Posted: December 5th, 2008, 7:09 am
by abiba_69
I had an 89 chrysler daytona intercooled turbo. They had a stock 42mm TB on them. When i put on a 46mm or even overkill 50mm throttle body from a van, direct bolt on, there was nothing gained except visits to the gas station. If your looking to change throttle bodys, i would suggest also looking into an upgrade in FPR and injectors. And like other posts, mass air and some other sensors. I new curve may have to be set in your PCM also to adjust everything properly. If not, you may end up burning out valves. I'm still new to the Mazda scene but i have learned stuff through other applications.
Good luck and hope this helps.
Chris
