I swear I'm going to rip my hair out over this!
mx3biotch
Also, I find it iffy to believe that my problems are coming from plugs or wires because even when it kept dying on me it was running as good as it ever has and it just needed a cool off period to start up again, then it ran perfect. I never had the idling problem til I did the fuel filter and ignition coil, so i think it might have just been my timing off but I havn't had a chance to drive it after we set the timing due to the fact that it wouldnt start! Tomorrow I'll try another HEI module when my parts store opens up again, haha.
94 GS, J-spec KLZE, KL31 ECU, KL31 Cams, Fidanza Lightweight Flywheel/Clutch, Custom CAI with K&N, NGK Plugs/Wires, Phenolic Thermoblock Spacers, Custom Magnaflow 2" Exhaust, Custom Titanium Paint, Carbon Fiber Altezzas, 16" Miata Wheels, Crossed Drilled Rotors w/Silver Calipers, Tint, Ground Control/Tockiko Suspension, Ground Control Rear Strut Bar, 6 Point Roll Cage, Corbeau CR2 Seats, Sparco 3 Point Harness, MOMO steering wheel/drifting e-brake/shifter, mx3 door sills/pedals, Carbon Fiber dash inserts, Silver vinyl door insterts, JBL power series 6.5" front components/4x6 rear components, 4 channel amp, infinity 10" self powered sub, JVC 2.5" DVD/Mp3 Player.
- Custom_V6_Limited_SE
Ya, if you recently replaced the wires you shouldn't have to worry about that. It is probably the HEI.
'93 MX-3 GS SE:My Mods
mx3biotch
well the HEI is only 40 bucks and my coil is brand new, lol, and thats okay
