Page 2 of 3
Posted: July 11th, 2007, 6:46 pm
by dillon
thats the diagram ive been following, ive checked it dozens of times and it wired correctly,
now for starters, when i dissconnect the coil wire front the dist and hold it up againts something metal it will only spark when the key is turned forward and turned back, not during crank, so there for the dist wont spark at all, so once i fix that problem i can diagnose further, so what do u think the no spark problem is?
Posted: July 11th, 2007, 6:53 pm
by Mnemonic
your positive you have the wires hooked up to the coil right?
Posted: July 11th, 2007, 7:36 pm
by dillon
coil u mean the 12V blaster coil and yes, postive to positive and negative to negative
Posted: July 13th, 2007, 6:29 pm
by Unicorn
get thicker wire, its suggested 16 guage, although i got away with 18 guage
Posted: July 13th, 2007, 7:22 pm
by dillon
im running 12guage,
Posted: July 14th, 2007, 11:56 am
by dillon
update....
got new coil hooked it up and still nothing, check over everything a dozen times all is hooked up correctly,
buddie loaned me a different disty returned it all to stock and still nothing, im thinkin its something else, got any ideas, thanks
Posted: July 14th, 2007, 12:56 pm
by Tunes67
I know this is a bit late in the game to ask this question but.. Did you try to pull codes before you started this whole thing?
Tunes67
Posted: July 14th, 2007, 1:08 pm
by dillon
i did i had cam sensor and crank sensor i believe, and one other unrelated
Posted: July 14th, 2007, 1:16 pm
by Tunes67
Did you replace the crank position sensor? Thats not part of the distributor you know... Check the shop manual for its location and how to test it
Tunes67
Posted: July 14th, 2007, 5:57 pm
by dillon
ok update,
tested the cranksensor, checked out ok, as per the shop manual,
terminal A and B has .560 ohms, spec is .520-.580ohms
checked distributer
between terminal A-B getting .56 ohms
spec is .49-.73 ohms
from termial A to the post looking thing inside disty,
getting 26k ohms, spec is 20-31K ohms
last test was 12 volts to termial A at the 3 pin connecter, im getting nothing it suggest checking the MAIN fuse which is fine then the igntion switch the wiring harness,
so what should i do now, thanks
Posted: July 14th, 2007, 8:09 pm
by Tunes67
Well you said it yourself.. everything is checking out ok.. so the next item on the list to check is the ignition switch right? Wouldnt be the first time one went south
Tunes67
Posted: July 14th, 2007, 8:54 pm
by dillon
yup that was my next step, ill try and do that tommorow and ill let u no, thanks for all your
Posted: July 15th, 2007, 10:18 am
by Unicorn
well you say the cars not starting...have you checked fuels getting to it?
Posted: July 17th, 2007, 6:00 am
by dillon
whats the easyest way to check for fuel, cus no since u mention it, i dont really smell fuel
Posted: July 22nd, 2007, 1:47 pm
by dillon
update,
checked the ing switch, checked out ok,
re checked the red wire (terminal A at 3 plug on dist) has 12 volts during crank,
next is to check the wiring harness and ecu
anyideas?
oh and it has fuel
