V6 ENGINE GURUS NEED HELP (noobs need not apply)
Mnemonic
Post by Mnemonic »
NEW PROBLEM Number 3 plug wire is no longer firing, I swapped the radiator plugged it all back up, looked for loose wires, none its just some how stopped firing......
i have the hei/blaster mod as well...
Soon to be 93 mazda mx-3 SE KLZE come and get it....
good night I'll try and figure out what happen thursday, i need to forget about this for awhile...
Thanks for the help bro (tunes) and all the other mx-3 guys who have been helping me on Aim (zoso, hppwdn). I'll let you guys know whats up as soon as i do.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Tunes67
Post by Tunes67 »
How did you test the #3 wire to see that its not firing? Did you pull the plug off the end of the spark plug and stick your tongue on it while cranking the engine? ;)
Tunes67
Mnemonic
Post by Mnemonic »
cheap mans test, pull the plug wire, and put it to one of the bolts on the valve cover, and if it arcs its sparking, or you can just pull the plug wire, and listen for a constant arcing sound inside the plug cyl
Tunes67
Post by Tunes67 »
Clip on a inductive timing light and pull the trigger while the engine is running.. watch the flashes for consistancy ;)
Tunes67
Mnemonic
Post by Mnemonic »
UPDATE
Well the 3rd cyl was firing after all, seems like i may have an injector going out, no biggie i got 6 spares. As for the overheating issue, seems like there was a leak from the o-ring on the pipe on that connects to the thermastat housing. We put a new o-ring in, new thermastat, and did a pressure test, seems like it was holding pressure just fine. Justin did think at 1st that it might have a bad head gasket because there were bubbles appearing as we were watching it, but as we kept burping the system and filling it up with water, they dissapeared and the water level is staying up. So the problem Might be fixed, but we are not really sure yet, since like i've stated it will only overheat under load, and you have to do some driving for a good bit amount of time to see what happens. So tomarrow i will be taking her out for about an hour drive to see if i can get her to overheat again...
Wish me luck, And a big thanks to the Moca crew ( Justin jaydog, Pat patdiesel, Chris cchreech) for coming out to my house tonight and giving me a hand, sorry that you guys got your arse handed to you in halo 3 beta though :)
Will update as soon as i have an update
Mnemonic
Post by Mnemonic »
Update:
Ran the mx-3 hard today, Reving constantly to about 5k in most gears, basically driving like a bat out of hell, and putting some real force on the motor. Though i dont have AC i did push the button in and turn the fan on, this will still put a load onto the engine, as it causes the rpms to jump up to 1k.
Verdict
She didnt overheat at all, and seem to be running really good... Lets just hope it stays that way for awhile. I'll hopefully be picking up a DD early next week, going to go look at a 95 camry for the daily, not great to look at but there good reliable cars that get a decent amount for fuel.
Anyway I'll keep people posted...
Thanks to everyone that helped again, and tunes you never called today ::cries:: I had to watch like 5 hours of Jackson Pollock documenteries for a report i'm doing and i was hoping to have some interuptions!!!!! hehehe :)
