LSD Options
- tehbrookzorz
SmoothMX3
Re: LSD Options
Just to let you know... The zx2's tranny is crap. Just trust me.
--- K8 was my gateway drug.
Re: LSD Options
Well i'll let you know cause those are the gears going in mine. Same gearset, but better syncros, which is a common problem in our trannies
SmoothMX3
Re: LSD Options
Ok... That's cool. But do this...
Go to TeamZX2.com and roam around the threads made about the trannies. You'll see 90% of the people there has a big problem with either the Diff. or Syncros. Also, Everyone on there will let you know the trannies area peice of 'you know'.
Not doubting you, just warning you.
Also, if you are going to do this... I have a zx2 tranny... The diff went out in it but ill let you have whatever ya need off of it pretty cheap, being i dont need or use it.
Re: LSD Options
SmoothMX3 wrote:Just to let you know... The zx2's tranny is crap. Just trust me.
was it you who owned a Zx2 at one point?
1996 MX-3 GS - rollin' on Rota Slipstreams, (Red, Deep Tint, Black Lip)
True Straight Neck KLZE with TB relocate. Custom Cold air Intake. 2.25 Exhaust to Bosal muffler.
ACT Stage 2, Fidanza Lightweight Flywheel, Short Shifter with CorkSport Bushings and SS Clutch Line.
Suspension Techniques Springs On Zx2 Struts. SRD Control arm Bushings, Custom Sway Bar Links
SmoothMX3
Re: LSD Options
Yep... And still do. It's in the back yard. After spending alittle over 3 grand the tranny took a poop, after i just had it worked on. So I got mad and sold alot of parts and threw a center block threw the drivers side rear small window! It was fun!
