Complete Miata Cam swap for B6, everything I need?
thats awesome! thanks jon, hey when you do go through with the swap, do you think you could take some pics?
94 mazda mx3 rs 1.6l DOHC... probe 4-2-1 header, 2" catback, a spec CAI, advanced ignition timing, NGK plugs/ wires, obx light wight crank pulley
http://www.cardomain.com/ride/2754605/1
I need some opinions.
OBX's specs on their cams are:
Stage 1: Duration (Lift mm): IN. 256, 9.0; EX. 256, 9.0
Stage 2: Duration (Lift mm): IN. 264, 9.0; EX. 264, 9.0
Integral's specs on theirs are:
Stage 1 248° .343" (8.71 mm)
Stage 2 254° .360" (9.14 mm)
Stage 3 260° .375" (9.52 mm)
Does anyone have an opinion of which is the best application without changing the valvetrain?
I THINK that the OBX would be a better bet, having not as high a lift, but I'm not sure what the duration is going to affect? Them stage 2's have a longer duration than Integral's stage 3's.
Opinions welcome, desired, wanted!
well those obx ones are the ones that i am planning on buying as well, and while i may not have have any experience with the quality of their cams, i do have an under drive pulley from them and i love it!
- Limegreen mx-3
anything above a stage 2 camshafts and ur going to have to upgrade ur valvetrain..
stage 2 and below u'll be fine with the OEM valve train.
