Just bought mx-3... But was it worth it???
i bought my mx-3 for $650 only cause the owner thought there was a major electrical problem with it cause it would intermittently not start up, they were obviously to blind to see the coil wire that was completely eaten away by battery acid. I replaced the usual things in a tune up, disty cap and rotor, plugs, wires, pcv valve, o2 sensor. car runs like a dream only other issue was a leaky valve cover gasket which was also replaced. has some minor body flaws suchs a minor dents and then the hatch garnish was broken off. other than that the car is great, minus the crack in the dash and missing master power window switch, but for $650 im not complaining the car is mechanically great, i drove it 70 miles to work and back for a month and had no problems. you just got to find the right deal. i have a BP lined up out of a 92 escort lx-e that is gunna be dropped in this summer.
