14.43 @96.94mph last night haven't changed a thing on engine
- Custom_V6_Limited_SE
I will second that.Slammed6 wrote:There is a sensor 1ft in front of the line where u stage. Your reaction time is timed from when the light hits green til you hit that sensor. Then your 1/4 milr time is started when you cross that sensor.
So your reaction is not added to your 1/4 mile time.
'93 MX-3 GS SE:My Mods
- slimmyslim1420
Ok cool, that was the first time I had ever even been and I didn't really know a lot about it. Thanks for the explanation though.Slammed6 wrote:There is a sensor 1ft in front of the line where u stage. Your reaction time is timed from when the light hits green til you hit that sensor. Then your 1/4 milr time is started when you cross that sensor.
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
No problem,slimmyslim1420 wrote:Ok cool, that was the first time I had ever even been and I didn't really know a lot about it. Thanks for the explanation though.Slammed6 wrote:There is a sensor 1ft in front of the line where u stage. Your reaction time is timed from when the light hits green til you hit that sensor. Then your 1/4 milr time is started when you cross that sensor.
I didn't know a while back when reading something like this...so i researched it and found out how the tracks work...LOL.
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
There are two sensors,
Prestaged and Staged
when rolling up to the line you break the prestage beam first
so give you warning to slow / crawl till the staged light comes on.
The tree can be run in two formats
full staging where each light stage comes on indervidually
or
Pro tree where the red's all light followed by all the yellows then Green!
Pro tree is harder to race and easier to break out on. but makes for
faster elimination rounds.
Id like to say thats a nice number you ran and to Hec shut your cake hole
as you post a lot of moose poop and really at the end of the day just
cos you can't cut the mustard, does'nt mean no one else can.
( waits for a warning from barry )
or
rev limiter on a de and ze are exactly the same, so this 7100 for a de is bull and ze ecu will still limit you at 7500mazdaspeedmx_3 wrote:how do you figure its gonna blow buds
i've put over 46000 kms on it
not a single knock or any other irregular sounds
its funny i had always thought a ZE and a DE were different engines
maybe thats why the factory rev limiter on a DE is only 7100 or 7200 rpm
why would the rev limiter be at 8000 stock if the can't even touch low to mid 7000 for a couple seconds
- mitmaks
Re: 14.43 @96.94mph last night haven't changed a thing on en
what are mods to your zemazdaspeedmx_3 wrote:Its only gonna get faster guys.....still have an exhaust leak
theres so many factors that come into play i knocked off .25 of a second
and i didn't do a thing...its all in the air and temperature
an incompetant driver can do a number on your time....the funny thing is i totally missed second gear took me 2 tries to get it in and i still ran 15.2 hahahaha tells you something about your drivin eh boyz
reaction--- .8289 if you want a pic of my ET slip email me at
60ft----- 2.1921 mazdaspeedmx_3@hotmail.com
330ft --- 6.1201
et @ 594ft-- 8.7722
1/8th et---- 9.3609
1/8 mph--- 76.45
1/4 et--- 14.4372
1/4 mph-- 96.94
my mods are 95 curveneck ZE, CAI, lightweight crank pulley, HEI module, and a $30 ebay chip in a kl07 ecu with JE50 Vaf...
that it
but i had half worn toyo proxes 4's on stock honeycomb rims and kyb gr2 struts with dropzone lowering springs....i've just got my engine runnin really well....my ZE has never been to a garage or mechanic since i put it in my car
that it
2006 best ET 14.43 @ 96.9mph
93 MX-3 GS-95 Curveneck klze, kl-01 cammed,homemade CAI,HEI module, chipped kl-07 ECU,UDP,KYB GR-2 struts,DropZone lowering springs, Toyo Proxes 4's 205-50-r15
parts to be installed:Turbo hot pipes,T04E/t3 50/63 57 trim, ssqv BOV, hks style 38mm wastegate
the rest of my turbo set up and IPP hp rebuild kit is in the NEAR future
SOON TO BE MX-3ZE-T
SOON TO BE MX-3ZE-T
- mitmaks
what are you saying, youre running one of those resistors off of ebay for $30
no an eprom chip....i had to desolder the chip from the ecu and solder in a new chip its like the brain for your ecu it controls the actual engine funtionsmitmaks wrote:what are you saying, youre running one of those resistors off of ebay for $30
it makes it just like a kl31/36 ecu
SOON TO BE MX-3ZE-T
SOON TO BE MX-3ZE-T
