Page 2 of 5
Posted: August 16th, 2006, 8:55 pm
by ariesdude
Tunes67 wrote:3 1
4 2
If thats your firing order.. assuming thats representing the 4 corners of your distributor cap.. then it looks like your distributor or firing order are 90 degrees off.. at least according to the diagram below found on page G-29 of the online manual.
You should be seeing
1 2
3 4
Cheers
Tunes67
3 1
4 2
is the correct order - the manual is wrong on that one. Chiltons shows the correct order.
Bumpy - Have you tried blocking of EGR?
Posted: August 16th, 2006, 8:57 pm
by Tunes67
Very possible. Still take pics of the cam gears and line up the timing mark on the crank pulley when you do so. That will tell me a lot.
As for my GS... No race engine yet.. the K8 is still young.. I am converting the car from ATX to MTX and I am prepping it for paint as I go. Also the drivers fender is off as well as the drivers door (got new ones). Currently I am stripping everything off the firewall so I can paint the entire engine bay black. The car will eventually end up charcoal grey with a gold metal flake and bronze Konig Helium rims. Eventually I will add a 94 Can GS spoiler, rear mudflaps and fade mirror tinting. Then I get to start on the interior
Once all this is complete.. I will be selling my RS and buying a KLDE to build for the GS when the K8 finally gives up the ghost (or whenever the DE is complete). Cheers
Tunes67
Posted: August 16th, 2006, 10:36 pm
by Bumpysbro
ya thats what i thought cuz if u put them in 1 2
3 4
it wont even start. ima take some pics right after the engine cools off so i can jack her up LOl
how do u block off the EGR?
Posted: August 16th, 2006, 11:10 pm
by Bochek
Bumpysbro wrote:haha lucky, are u doing a full race engine for ur gs? hey if the disty is 90 degrees off and it runs, then the valve timing is off by the same right? thats why it runs like crap when u put the plug wires on diff.
if its 90 degrees off and it sill runs, it should run backwards no?
lol j/k
i still think one of your cams is off by 1 tooth. dont forget, i could just be one cam, not both of them.
Bochek
Posted: August 17th, 2006, 12:14 am
by ariesdude
I think the easiest way to block egr is disconnect the egr pipe from the exhaust manifold and put some kind of blockage in the pipe (like put small piece of paint can lid or something like that) and connect it back again. That way you dont have to mess with the electrical stuff and no exhaust gas will get into the intake...
Also check the vaccum lines going to the FPR - it might be possible that you have reversed them or connected them wrong. I am running with a direct vaccum line from manifold to the FPR and its working fine.
Posted: August 17th, 2006, 7:32 am
by Bochek
on that note, did you reverse your fuel lines by accadent?
Bochek
Posted: August 17th, 2006, 4:50 pm
by Bumpysbro
thats what i thought i did, but i checked em and their right...hmm ill try that and see what happens. i took some pics of the cams and the gears.
http://img334.imageshack.us/my.php?imag ... ew3ap2.jpg
http://img219.imageshack.us/my.php?imag ... ng2yp3.jpg
http://img.photobucket.com/albums/v381/ ... o/cams.jpg
here are some pics, as u can see both intake and exhaust cam are on E. but if we used the intake on I the 4th piston would be TDC. with intake on E #1 cylinder is is TDC and the process seems to be right. does this help tunes? i couldnt get any pics of the crank pulley cuz the camera was to big to get in there lol, but the pulley boss was right straight up and is timed by my eyes. ill check the FPR hoses aries and see what happens. thnx guys
Jon
Posted: August 17th, 2006, 10:16 pm
by Bumpysbro
well i tried reversing the FPR lines today and made no difference. shouldnt it run worse?
Posted: August 17th, 2006, 10:37 pm
by Tunes67
Ok its hard to see in your pics.. but if both your cam gears timing marks are E's pointing down towards the center of your engine.. then your Exaust cam is incorrect. Oddly enough.. according to my shop manual.. your exaust cam should have the I pointing downward and towards the center of your engine. The I should be pointing straight up on the top of the intake cam and the E should be pointing straight up on the exaust cam. The pic in the online shop manual isnt a very good scan.. I will take the page with me from my shop manual too work with me in the morning and scan the pic I have so you can visually see what I am talking about. But from those pics.. your exaust cam is incorrect.
Tunes67
Posted: August 18th, 2006, 1:01 am
by Cy
1.1 light.
shift @ redline every gear
got to the end of the Track in 17.1
Posted: August 18th, 2006, 1:26 am
by Bumpysbro
how fast were you going when u hit the end of the track? was it a 1/4 mile?
Posted: August 18th, 2006, 2:51 am
by lowflyinmx3
i ran a 17.3 shifting at redline. i was at 76 mph and i shifted out of 3rd at exactly the same time i crossed the line.
Posted: August 18th, 2006, 3:39 am
by Bumpysbro
wow thats krazy, my car cant even reach 76 in 5th lol
well ripped her apart today, redid the timing just like u said tunes and bam wont start. put the intake cam on E and the Exhaust cam on I. so i dunno whats up with it, it runs if the exhaust cam on E but it wont on I. the marks are all lined up right and everything is pluged in so i dunno haha. ima take her apart again tomorrow too tired tonight.
Posted: August 18th, 2006, 9:19 am
by Cy
track day @ the Miramichi:
I have no interior paneling, no rear seat, no spair tire, no carpet, no center console and i did have a passenger seat...
I ran 14" winter tires @ 10psi and I had only my trunk battery installed (i use both front and trunk normally)
I ran consistant 17.2 - 17.35 all day....no tuning.. just havin fun
RT 1.156
60ft 2.646
330ft 7.277
Mid mph 64.10
660ft 11.103
990ft 14.286
MPH 79.64
ET 17.175
i'd just be shifting into 4th just before the line, just like he did...
That's my best ET my best mph was 80.06 but I ran a 17.311
Posted: August 18th, 2006, 9:36 am
by Cy
this kinda had to be another post...
When i do an oil change i take of the valve cover just to inspect the cams and stuff for anything odd... Well bout a week ago (just before i went to the strip) was the first time I had to change the oil in the mx-3... so i pulled off the cover and lone behold my exhaust cam is like 5 teeth advanced... FUN STUFF...
So i had to retime the motor which i've never EVER done.. on any motor...
Just a quick FYI...if you have 2 people... you only need to take off down 2 the 2nd timing belt shield and loosen the belt tensioner..
Then i just used 2 rachets to hold the cams in place while my friend slipped the belt on...
I'm running +1 degree on the crank and +1 tooth on both cams so i'm like 3 degrees retarded...on a bone stock N/A engine
The power of that configuration is nice.. it's not top heavy but there's definetly power up there..
