What do your maps look like on the safc?cjthor wrote:How bout saying screw the rising rate and just use my afc to adjust? Im runing 320 cc injectors and i wonder if the afc is fighting with the rrfpr for adjustment. THOUGHTS???
Pressure regulators
- cjthor
-20s to -30s across the board both high and low settingsnos92mx3 wrote:What do your maps look like on the safc?cjthor wrote:How bout saying screw the rising rate and just use my afc to adjust? Im runing 320 cc injectors and i wonder if the afc is fighting with the rrfpr for adjustment. THOUGHTS???
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
cjthor wrote:-20s to -30s across the board both high and low settingsnos92mx3 wrote:What do your maps look like on the safc?cjthor wrote:How bout saying screw the rising rate and just use my afc to adjust? Im runing 320 cc injectors and i wonder if the afc is fighting with the rrfpr for adjustment. THOUGHTS???
What are you doing about your TPS?
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
- cjthor
on the DOHC engines the afc reads a linear signal. I can read 0-100 percent throttle not just on and off.nos92mx3 wrote:cjthor wrote:-20s to -30s across the board both high and low settingsnos92mx3 wrote: What do your maps look like on the safc?
Jarid Perry
- cjthor
You used a super afc for a bit right? And im pretty sure you had larger injectors...what were u running for an fpr?Josh wrote:thats what it sounds like to me. i drilled my stock FPR out so its there but flows like a mother fo. i was running a cheepy MSD one and it worked great, now i have this bad a-- comp tech FPR to go with my stand alone.
Jarid Perry
On my dads 1.6 we added a turbo and RRFPR and injectors from larger sized mazda and larger fuel pump. we tried to tune with a safc but since its a 94 the computer does what it wants regardless so we set safc for 0 and just worked with stock timng and rrfpr and the car boosted to 6 and 7 psi nicely.
I am going to try the safc in my bpt setup to get idle under control.
