Posted: May 4th, 2006, 2:14 pm
For the HEI mod - one thing that was left unmentioned was that you have to disable the stock ignition module. If your stock module is bad and is shorting the trigger signal - the external HEI module will not work no matter how better/powerful it is.
You can disable the stock module in two ways -
-Remove the module from inside the disty
-Cut the connections that go to the module (I cut the orange wire and the adjacent wire - it is important to cut both because the other wire is the stock module ground - if you left it uncut the stock module can still short out the internal coil)
