Page 2 of 4
Posted: March 31st, 2006, 1:35 pm
by JWMotorsports
Your friends integra needs some tuning then (I'm don't mean this in a mean way)...my GT3076R DWARFS a T3/T04E and mine is on a 1.6l B6T w/ stock bottom end running 24psi.
As for where to purchase the turbo:
http://www.corksport.com (I got the 30R and the GT32 both from Corksport)
http://www.atpturbo.com
http://www.cheapturbo.com
Posted: March 31st, 2006, 3:40 pm
by osargeant
I still think that a T3/T4 is too big for a 1.6 engine also, the GT series turbo are ball bearing and would spool a bit quicker. The T3 Super 60 is just a great match for the 1.6 engine and it can support the boost levels (15-20) that Jarid is looking to run.
Posted: March 31st, 2006, 4:44 pm
by Franko
Gt series turbos spool CRAZY fast! No wonder they cost more than some cars. :P
Posted: March 31st, 2006, 7:03 pm
by cjthor
im waiting for a call from derrick to go over turbo specs. hopefully I can keep the business local!
Posted: March 31st, 2006, 8:11 pm
by babyblueMX3
try atp turbo, they have good stuff on their site
after checking the maps for both t3s60 and gt28rs, I come to think that the t3s60 would be a really good match. You'd have decent power till 6500rpm. actually it would be similar with the gt28rs. You'd probably get a faster spool up with the gt but it will cost around the double for the turbo. It's all the matter of money
After looking a little bit more at the maps a GT30R would also be a reallly good option to go with. Actually it would be my first pick if you were to go the 20psi route.
Posted: March 31st, 2006, 8:24 pm
by cjthor
babyblueMX3 wrote:try atp turbo, they have good stuff on their site
Thank you!!!!!!!!!!!!!! I was looking at the gt30r actually....
Posted: March 31st, 2006, 8:59 pm
by cjthor
Is there a program that I can get where I can plug in A/R values and such and it will show me the map of the turbo? Looking at atp's website and looking at the Garrett GT2871R and not sure of what a/r to use.. You guys have been a big help. Definitely going with a GT ball bearing!!!
Posted: March 31st, 2006, 9:06 pm
by babyblueMX3
actually I made a little one with exel sheets and it has pretty much all the compressor maps.
If you can catch me on msn or aim sometime I could send it to you
Posted: March 31st, 2006, 10:26 pm
by JWMotorsports
If your looking at the 2871R from ATP then I'd reccomend the .63 A/R T3 4bolt housing with the TO4E 4" compressor housing upgrade.
Posted: April 1st, 2006, 12:01 pm
by cjthor
JWMotorsports wrote:If your looking at the 2871R from ATP then I'd reccomend the .63 A/R T3 4bolt housing with the TO4E 4" compressor housing upgrade.
This turbo wont have alot of lag?
Posted: April 1st, 2006, 1:54 pm
by Josh
no way, the GT28/71R is going to spool way fast, and definatly give him the power and reliability. no it wouldent have that much lag. compaired to your existing T3. you probably spool around 3K to 35 now rite. well the GT28/71R will be about the same on a 1.6, at the very latest 4K, but you would be making an easy 250 to 300 WHP at 10 to 15psi. its a damb nice turbo. Well on the other hand Bugs and I have a bunch of IHI VF12's comming in from AUS, and they are a 300 WHP @ 15psi bolt on for a milled VJ20 exhaust housing. they are a bit laggy on a 1.6 spool is about 3800.
Posted: April 1st, 2006, 1:57 pm
by osargeant
Hey Jarid,
You may want to look at this post from a Miata web site.
http://forum.miata.net/vb/showthread.php?t=13860
It is relevant based on what we are discussing here.
Posted: April 1st, 2006, 2:27 pm
by JWMotorsports
It will still have some lag which is a good thing actually for traction. It should spool quick around 3500 RPM and be full song by 3800 RPM. You'll actually have some boost under 3000 RPM. That turbo setup will support around 400HP. Here is a quick ref. chart to compare a few of the turbos we've been talking about:
T3 60 = 250HP
T3 Super 60 = 280-300HP
GT28R = 300HP
GT2860R (aka 28RS) = 350HP (aka Disco Potatoe)
GT2871R = 400HP (uses larger compressor on 28RS CHRA)
GT2876R (aka 25/40R) = 450HP
GT3071R = 475HP (smaller comp. wheel on 30R CHRA)
GT3076R (aka 30R) = 500HP-600HP (aka HKS GT3037 ProS)
GT3082R (aka 35/40R) = 600HP (uses 35R compressor on 30R CHRA)
GT3582R (aka 35R) = 600-700HP (aka 35/40R)
GT4088R (aka 40R) = 700HP
GT4294R (aka 42R) = 850HP+
GT4294RS(aka 42RS) = 1000HP+
For those that still need convincing that the old T-series is no comparrison to the new GT"R" series check this ATP dyno comparrison between a GT28RS vs. a T3/T4E on the same car. The GT"R" series turbo used a larger A/R exhaust housing and still out performed the old T-series turbo in ALL aspects! http://www.atpturbo.com/root/turbopipin ... gragsr.htm
Posted: April 1st, 2006, 2:46 pm
by JWMotorsports
Josh...you took my post the wrong way. ATP offers a .63 A/R T3 4bolt Exhaust housing to use on the 2871R CHRA and also offers the compressor housing to be upgraded to a 4" T4E which will allow for a higher flow on the compressor side. The CHRA (center section housing, bearings and wheels) are still the GT2871R's. His manifold uses a T3 flange and that is why he needs to use a different exhaust housing. The standard exhaust housing for the GT2871R is the T25 housing. Also the housing I suggested uses a 3" 4-bolt flange allowing a full 3" down pipe minimizing lag and optomizing both HP and response. I can tell you from experiance the smaller your down pipe, the slower the turbo responds and it also makes a very noticable difference in power out put.
Posted: April 1st, 2006, 2:51 pm
by cjthor
Lots of good info guys. Since Corksport built my motor I want to speak with them before pullling the trigger on the gt turbo. I will have my decision Monday!!!
