NEW MX-3... We'll see (Picture inside)
precidian
Post by precidian »
Juans_93_MX3 wrote:I hope to god they dont put a Rotery in it, those engines are crap... CRAP
Seriously, who wants some gas hogging POS of a engine that burns oil all the time while providing weak Torque?
Rotery engines are a bad idea
seriously...have you had any experience with a rotary engine? Why are they crap? please explain.
Also, all engines should use or burn some oil and if it doesn't then I think you would have some serious issues.. I hope one day you don't a porsche, they also use oil and have to keep a close eye on the oil level.
BTW... spelling ownz you...it is rotary.
Tom S. - '94 MX-3 GS-X Sparkle Green
I say, Ahmed. What is that thing you do when you're about to assassinate an infidel?
relisys_3200
Post by relisys_3200 »
hmmmm...dont think I've ever heard of a "rotery", must be a Utah thing.
I think a good rotAry platform will help this car out alot.
...and every car will burn oil after awhile :roll:, that's even a big k-series thing with higher miles
Brandon
1992 MX-3 GS-ZE
Flashpoint2
Post by Flashpoint2 »
AND the torque they provide isn't that weak.. in fact it's quite on par with most piston engines. For instance, the Celica GTS puts out 180hp/130tq.. ANY rotary except the carb'd 12a puts out a better ratio than that.
1996 MX-3 RS - Sold.
2004 RX-8 GS - Yay!
Aren't rotaries designed to inject oil to help lubrication? I remember reading/hearing something about some rx-7 owners wanting to add a seperate oil resevoir just for that.
BTW, my ZE burns oil. I have to add 1L betwee oil changes
DavidOS
Post by DavidOS »
umm rotary engines are amazing especially the new one. SOOO much potential with them and they weight nothing, and seemlessly rev higher and higher. They can build them bulletproof if they want.... Their power levels are good naturally aspirated, 3 rotors NA are a perfect example of that and its torque is equally good. If you want more torque then add
OR MAYBE your thinking of a different engine Rotery is alot different then ROTARY.
Juans_93_MX3
Post by Juans_93_MX3 »
Im saying, if they put a Rotary in the new MX3, its a awful idea.
So far, I havent seen ANYTHING special coming out of any rotary based car
RX8? Can you say extremely WEAK? Crappy power?
Those engine burn about the same amount of fuel as V8s, yet V8s make alot more power.
Any successful rotary based cars? None
It would be nice to have a rotary engine in a project car but it’s a bad idea from automakers to include one.
Those are the reason why I think Rotarys are crap.
2008 Mazda 3
1993 MX3 GS
Tunes67
Post by Tunes67 »
Do you ever get tired of talking out of your A$$? Successful Rotary powered cars.. hmm... How about the RX7? *Gasp* This car went through 3 generations before mazda pulled the plug on it.. which I bet everyone here will agree was a mistake on mazda's part. Oh and did you know that rotary powered cars have been banned from almost every racing sport? Do you know why? Because they beat the living crap out of conventionally powered cars. Their horsepower to weight ratio makes them perfect for racing.. and just like any engine.. the power you get out of it is directly proportional to the work you put into it.
Rotary engines only have 2 main draw backs.. They tend to be more expensive than conventional engines and they tend to wear out quicker than conventional engines. But.. that was the rotary engines from the 70's, 80's & 90's. Technology has advanced to a point where they can make the Wankels much more efficient and durable.
Oh and since you have never been for a ride in a car with a built rotary, maybe you should just save your presumptous opinions. There was a video floating around a while back of a twin turbo RX7 that was making 650 HP. The speedometer was moving so fast upwards that everyone thought it was a tachometer. Comparing a V8 to a rotary is like comparing apples to oranges. Its a biased comparison on your part since you like V8's so much. How much does your V8 weigh? How much does the car its in weigh? Ahhh.. see thats where the different perspective is.. Mazda doesnt need to put out a engine that has to move so much weight. So they save weight be using the rotary to begin with. And they put it in a lighter car.
You know what? I just realized I am just wasting my time here and your not worth it in the slightest. Sell your mazda and go get a mustang.
Tunes67
Billyd
Post by Billyd »
I'm sure it's rotary....Mazda has invested too much money for it not to be. Nice looking car though.
