Posted: January 19th, 2006, 10:18 am
It depends on if anyone was there to see the balls falling.FlyVFR wrote:If 10 lb and 15 lb bowling balls are released from the same height at the exact same time, which will hit the ground first
Then take to a nice flat 7000 ft runway and race airplanesCustommx3 wrote:The Mx3 will surpass 140. Ive rode in 2 MX-3 ZE's and hit 150. I havent tried in mine yet, I'm going to get some good suspension 1st.
lakersfan1 wrote:It depends on if anyone was there to see the balls falling.FlyVFR wrote:If 10 lb and 15 lb bowling balls are released from the same height at the exact same time, which will hit the ground first
I believe the 150 is possible with the MX6/626 tranny and delete rev limiter with a rechip or Megasquirt.XxantwawnxX wrote:Kinda hard to reach 150 when the tranny runs out of gearing at about 140 or jsut before. I have a ze mx and i cant reach 150 because im in 5th gear redline(or just about) at 137-138.
tatsu already posted figures for top speeds. Now, how quickly the MX-3 reaches point A to point B as compared to the probe should be a declining figure starting at 4% (estimated by tastu) while both cars travel to reach top speed!Amma351 wrote:My bad guys!
I forgot to specify my question, How much faster would the mx3 be?
a car lenght? more?
Thanx
Umm...no it won't not with stock tires and tranny. Doesn't matter the power it has, its in the gearing. My Mx-3 wanted to go fatser but couldn't, and i had a 205/50-15 tire/rim combo. ~139 MPH was the limit at 7000 RPMThe Mx3 will surpass 140. Ive rode in 2 MX-3 ZE's and hit 150. I havent tried in mine yet, I'm going to get some good suspension 1st.
