colt cams solid lifter cams
- fieromx3
well i may be thinkin wrong but babyblue u said they dont work like they r supposed to at high rpm. if i did do solids could i possibly gain high end power under boost? im thinkin now after all ive been reading a 8000 rev limit
my dream of the revs id like r gone. so basically if i do 8000 rpm and stick with hla's and nore aggressive cams i would probly have the same effects as solids?
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
lakersfan1
OK. Solid lifters are dinosaurs, but Mazda converted all thier cars AWAY from hydraulic lifters in 1998.markmclean wrote:solid lifters are dinosaurs. with the advent of roller cams and hi perf hydraulics, the need for solids has all but gone away. Only if you were running huge HP (like into the several hundreds to thousands) would you need a solid lifter. At those HP outputs, lifter quash becomes an issue, where the lifter collapses under load, binding the springs and valve train. while there may not be a roller setup available now, the hydraulics will work perfectly well for the power gains youre looking at. be sure with whatever cam profile you decide on that the valve springs are rated for the lift. otherwise if they are not stiff enough you can bind them at high rpm. as far as a more aggressive grind? he may be right in stating that the stock cam profile is a tad conservative for optimum power. car makers do this for the sake of overall reliability and fuel economy. The more aggressive cam will improve the torque curve and overall powerband when used with the turbo.hope this helps
markmclean
- babyblueMX3
if sticking at 8k sure you could keep hla's IMO.fieromx3 wrote:well i may be thinkin wrong but babyblue u said they dont work like they r supposed to at high rpm. if i did do solids could i possibly gain high end power under boost? im thinkin now after all ive been reading a 8000 rev limitmy dream of the revs id like r gone. so basically if i do 8000 rpm and stick with hla's and nore aggressive cams i would probly have the same effects as solids?
A buddy of mine told me the other day that you can mod the stock hla's to make it work at higher rpms. drill the hole half a millimeter more or drill another hole the same size on the opposite side. This way the hla will bleed faster at higher rpms but suppose to have a little clicking noise when cold.
That's maybe the route I'll take I don't care about cold since the car doesn't see it
RIP 400whp ZE-T MX-3
- babyblueMX3
I was browsing through miata forums when I saw a couple of places that on the 99+ miata (wich used solid lifters) the manual said the lifters have to be checked/reshimed each 60k km. Now I don't know if this is true for all other engines but I would have guess so because it does the same thing and wears the same too.lakersfan1 wrote:I've got a 2000 626 with solid lifters. 85K miles. No reshimming yet.babyblueMX3 wrote: many people told me solid lifters increase wear on valve train and they have to be reshimed every 30k km or so.
Just though I'd trow this here
- JM1EC-V6
Yeah, it's totally true. You have to check the cam-lifter clearance, and adjust lash with shims designed for.
Here's a KLG4 (1998-2002 626 V6) Cam. Notice the different lobe design compared to HLA lobe profile. You can also see the lifter itself.
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
1110Kg
- babyblueMX3
some good info I found about running solid lifters with hydraulic lifter cams :
quoted from RodH on forum.miata.netThere's two issues.
1) the solid lifter must be set up with clearance to allow for differential expansion in the valvetrain, so the cam to drive it has an introductory ramp that is long and slowly changing, to pick up the mass of the valvetrain gently. An HLA cam does not provide this "soft pickup" so may be less suitable for use with solid lifter valvetrain.
2) Solid lifter cams are usually used with lighter lifters and springs, so they can have steeper opening ramps (knowing the lower opening forces won't break through the cam face). Heavier HLA valvetrain may lead to excessive forces and wear on a solid lifter cam (though I'm not convinced this is a big issue on OEM Miata cams).
- babyblueMX3
if you run solid lfter AND cams yes there's power to be made at higher rpms (8k+) but you would want stiffer springs too to prevent valve float.
Don't forgot that also the solid lifters (mostly shim under bucket) weights a lot less than hla's.
- fieromx3
thx thats the answer i was lookin forbabyblueMX3 wrote:if you run solid lfter AND cams yes there's power to be made at higher rpms (8k+) but you would want stiffer springs too to prevent valve float.
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
