when me and my friend put a FMIC in his talon we took a jigsaw and cut out a little slice of the rebar so it could fit up in there
just gotta be careful it melts to the blade as you cut
Well here is some pictures of my prototype intercooler setup
- happyclown
- XxantwawnxX
yea im pretty sure i can fit it if i modifie the pipe location a lil, if not im just gonna chop a lil section liek you said, it will def fit. looked at it some more today.
