What would you guys do?
yea i can hold them that long, the Passenger side has a side marker in it that needs to be replaced that a problem?
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- ryanlindenberg
the ticking noise is your HLAs (hydrolic lifters). i'm guessing they are ticking because the car was sitting around so long. change the oil and take it out for a drive and my bet is that it will go away after a little bit. maybe there is some kind of oil treatment that you can put in to help clean it out a little better???
you will probably want to put some fuel injector cleaner in the gas tank too.
good luck!
good luck!
CARDOMAIN WITH UPDATED PICS
hey you still need these parts, times starting to run out on my mx-3 junkyard i got going on in my driveway.
