Dyno schedule
As disapointed I am in my engine's hp output, but I'm actually quite impressed, for an N/A engine, that I have slightly more torque than horsepower.
Prob going to take the car to the shop and get this leaking gas tank checked out...see if it's actually leaking or not. Cause I never see a puddle under the car and the mileage has been consant since I got the car.
Friends are just enemies who lack the testicular fortitude to kill you.
I'm a 2min man in a 1min universe
94 GS - KLZE, Spec2 Clutch, Fidanza 9lbs FW, 2 1/4 full magnaflow exhaust. 145WHP / 147WTQ
Your telling me...I was super sad..when I came off the dyno..but when everyone else posted similar numbers I was a bit ok....need to figure out how to reduce the loss from over 50HP to something a bit more resonable..hehehehe
I don't know why your so worried and upset, my car has less power than Ian's
There is Ian when you need him anway, I was my dyno files
More likely...I wanna get one of the guys that where there to give me car a run
One question, about the colors on the Dyno sheet, red is RunFile_001.drf which is what I'm guessing to be my first run, and RunFile_002.drf in blue is my second run, right?
Hmm, so my cai robs me of about 20hp after 6000, interesting..., time for an Integra CAI mod!
The filter I have doesn't look all that clean, I was suspecting it was restrictive which is why I did a run with it removed. Look at my HP chart, look how the 2 runs aren't farily close to each other like every one else's, it cause I took my CAI filter off for the second run (red), which shows a significant different between it on and off.
I scaned in my printed out version, check her out in the V6 section
http://www.mx-3.com/phpbb2/viewtopic.php?t=45939
the ubb automatically resises it, but click on it, it'll open in full in a new window
Each bar is 5hp
Each bar is 5hp
AAAAAAAAH ... sorry I was only looking at your peak power..but ya that is a pretty massive diff at that range.
Did you run rich at 6k as well...my reading was off the graph...way off heheheeh
