Motor Mount question
- FIMotorMX-3
Thanks Lakers... I'm ordering it this weekend.
sold it to a friend.93 green MX-3 with ZE swap. KL36 ecu, modified carbon fiber intake from a civic hatch. Centerforce Dual Friction clutch from MX-6. black Konig Minuz wheels, Synthetic fluids, 3 gauge pillar pod with air/fuel, water temp and oil press. Autometer Shiftlight. B&M short shifter. 2.25 piping with a Greddy SP1 muffler, AWR urethane front motormount, pheno spacers, Intrax Springs, Mazdaspeed Sideskirts. The New Ride is a 2003 1.8t a4
check out myspace:
http://profile.myspace.com/index.cfm?fu ... D795345349
my cardomain: http://www.cardomain.com/ride/2142324 UPDATED!!!! 08/28/06 newest pics
check out myspace:
I just got back from vacation last night and decided to start my car for the first time in three weeks and when I started it the shifter shook like crazy. As the engine warmed up it stopped and I took it for a spin and it everything was good? Maybe just because it sat so long or maybe needs new mounts? not sure ![Question :?:](./images/smilies/icon_question.gif)
- FIMotorMX-3
It's probably because it sat so long. It was probably idling really rough, causing your shifter to shake a lot. The motor mounts will make the car feel like it's jerking when you shift or let off the gas. The motor will move around with the change in rpms causing the car to shake or jerk if the mounts are broken. Easiest way to check without getting under the car is to let the car idle, open the hood and press down on your throttle. If there is a lot of movement with the engine, a mount might be torn or broken.
check out myspace:
check out myspace:
