Delayed Power from Engine?
- vozaday2000
did you check your oil? and when your car stalls did it jump rpm's then all of a sudden drop to zero. the car can only rev to 8000 rpms. as for the oil light coming on all i can think of is either the oil is a little low and not enought was getting to the sensor at that rpms.
![Image](http://memimage.cardomain.net/member_images/10/web/730000-730999/730367_31.jpg)
- Tunes67
The ticking is probably your friction gear. Could be HLA's but that would be a lot louder I think. As for your engine bogging down.. Dirty fuel injectors.. run a can of Seafoam through each of your next 2 tanks of gas. That should help out a bit.. also run decent quality fuel. Stop using Safeway or AM/PM gas and go with Cheveron. Hope this helps.
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
Heh, that's probably the most helpful post I've ever gotten, thanks alot manTunes67 wrote:The ticking is probably your friction gear. Could be HLA's but that would be a lot louder I think. As for your engine bogging down.. Dirty fuel injectors.. run a can of Seafoam through each of your next 2 tanks of gas. That should help out a bit.. also run decent quality fuel. Stop using Safeway or AM/PM gas and go with Cheveron. Hope this helps.
Tunes67
93' MX-3 - V6 (complete!) KLDE Engine, KL02 VAF, custom fog lights ![Smile :)](./images/smilies/icon_smile.gif)
